Issued resolved. Thanks for all that helped.
				Results 1 to 29 of 29
	hi, open with notepaq ...
 #EXTM3U
 #EXT-X-VERSION:4
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=717742,CODECS="avc1.4D401E,mp4a.40. 2",RESOLUTION=384x216,AVERAGE-BANDWIDTH=351729,FRAME-RATE=29.97
 http://seamless.mtvnservices.com/api/mgid:arc:episode:vh1.com:e5c08d6c-8b87-11e6-bfd4-...3u8?proxy=true
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1111150,CODECS="avc1.4D401F,mp4a.40 .2",RESOLUTION=512x288,AVERAGE-BANDWIDTH=547685,FRAME-RATE=29.97
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=2021756,CODECS="avc1.4D401F,mp4a.40 .2",RESOLUTION=640x360,AVERAGE-BANDWIDTH=1011062,FRAME-RATE=29.97
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=2551846,CODECS="avc1.4D401F,mp4a.40 .2",RESOLUTION=768x432,AVERAGE-BANDWIDTH=1340673,FRAME-RATE=29.97
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=3864412,CODECS="avc1.4D401F,mp4a.40 .2",RESOLUTION=960x540,AVERAGE-BANDWIDTH=2019093,FRAME-RATE=29.97
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=6174300,CODECS="avc1.640028,mp4a.40 .2",RESOLUTION=1280x720,AVERAGE-BANDWIDTH=3062204,FRAME-RATE=29.97
 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=10651116,CODECS="avc1.640028,mp4a.4 0.2",RESOLUTION=1920x1080,AVERAGE-BANDWIDTH=5229441,FRAME-RATE=29.97
	Use one of those link with ffmpeg.
 Or with youtube-dlCode:ffmpeg -i http://seamless.mtvnservices.com/api/mgid:arc:episode:vh1.com:e5c08d6c-8b87-11e6-bfd4-0026b9414f30/5a571a1b-cc4c-4bc5-b0a2-caf5aa1647a1/384x216_293/playlist.m3u8?proxy=true -codec copy output.ts
 Code:youtube-dl http://seamless.mtvnservices.com/api/mgid:arc:episode:vh1.com:e5c08d6c-8b87-11e6-bfd4-0026b9414f30/5a571a1b-cc4c-4bc5-b0a2-caf5aa1647a1/384x216_293/playlist.m3u8
	Viacom seamless hls playlists should be avoided since they contain interspersed ad segments of varying and disparate quality compared to the content.
 This works fine in an online hls player, but not as much for a continuous video file.
 If nothing but the seamless playlist is available, the best solution for downloading is to edit a local copy of the playlist into separate playlists for each "act" of content (and discard all of the ad blocks). After each act is downloaded into a separate file, they can be joined if desired.
	I aborted the downloads after a bit and didn't notice that they would choke after a while. Ponens is right -- if you download the m3u8 file you'll see the segments, each with a new decryption key. I guess the downloaders can't handle that automatically yet.
	What about this?
 Code:https://keysvc.mtvnservices.com:443/get/encrypt.key?acl=gsp.alias/mediabus/vh1.com/2018/12/28/04/19/21/8f107820313643f8ae3492c7142d9a85/1447860/0&tk=st=1582995491~exp=1583017091~acl=/get/encrypt.key?acl=gsp.alias/mediabus/vh1.com/2018/12/28/04/19/21/8f107820313643f8ae3492c7142d9a85/1447860/0*~hmac=4b9c1a21332d2580ad8c2802a330d2f96810e89ab16e9fcb8108ad7f51f73a3c
	As mentioned in post #6, the best way to download a seamless playlist is to edit the playlist and use it locally.
 For this video, here is an example of how to edit the playlist: e5c08d6c-8b87-11e6-bfd4-0026b9414f30.zip
 Copy ffmpeg into the same folder with the edited playlists. Then run ffmpeg for each edited playlist;
 Code:ffmpeg.exe -allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls,crypto" -i "act1.m3u8" -c copy "act1.ts" ffmpeg.exe -allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls,crypto" -i "act2.m3u8" -c copy "act2.ts" and so on, through act9
	Okay so i get the editing playlist part but can you run down how to download the playlist with ffmpeg. Do i copy what you just coded? "allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls,crypto" Feel free to message me if you don't want to explain it public.
	Sorry. I get the editing the playlist part. When it comes to downloading the "acts" do i just copy and paste this "-allowed_extensions ALL -protocol_whitelist "file,http,https,tcp,tls,crypto" -i "act1.m3u8" -c copy "act1.ts" after copy and pasting ffmpeg on the same folder?
	I've tested out the example one you sent but it's coming out wrong.
 [Attachment 52199 - Click to enlarge]
	I'm out of ideas. It looks like maybe you didn't extract all of the files from the zip into the same folder, or that you aren't running the command prompt within the folder that contains all those files. Can't say for sure, but you probably should abandon any further attempts at this method.
	to test use this (works for me):
 to check if plays after 8 min add -ss 00:07:50 at the end of lineCode:ffplay -infbuf -user_agent "Mozilla/5.0 (Android 4.0)" -i http://seamless.mtvnservices.com/api/mgid:arc:episode:vh1.com:e5c08d6c-8b87-11e6-bfd4-0026b9414f30/607e4aa7-f47a-4f14-b85a-7fbd1731f93d/1280x720_3020/playlist.m3u8
	I was able to download the entire video using Streamlink and ventoux's URL. I didn't even need the user-agent string:
 The resulting mp4 file was about 932 MB. It would play in MPCHC wouldn't seek properly -- the timeline showed only 30 seconds but it continued playing to the end. A quick remux to mkv with ffmpeg resulted in a full video that played and seeked with no problems.Code:streamlink "http://seamless.mtvnservices.com/api/mgid:arc:episode:vh1.com:e5c08d6c-8b87-11e6-bfd4-0026b9414f30/607e4aa7-f47a-4f14-b85a-7fbd1731f93d/1280x720_3020/playlist.m3u8" best -o output.mp4
 Code:ffmpeg -i output.mp4 -codec copy output.mkv
  please help downloading m3u8 file - jawwy.tvBy karim1987 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Dec 2019, 14:44
  please help downloading m3u8 fileBy karim1987 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2019, 18:11
  Downloading AES-128 encrypted m3u8 fileBy achy635 in forum Video Streaming DownloadingReplies: 6Last Post: 29th Aug 2019, 00:51
  Help Downloading a m3u8 file with ffmpegBy nerdsmurf in forum Video Streaming DownloadingReplies: 4Last Post: 19th Jun 2017, 15:56
  Help downloading a m3u8 file starting at a specific segment.By qwerty480 in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Sep 2016, 01:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
